Work in progress...
Vääntöjen vääntö, mutta alkaa olla valoa tunnelin päässä.
Updatea. Sanotaan, että alpha 1.
Max toolit
Mesh export
struct meshExportStruct
fn exportMesh m strName =
t = m.transform
m.transform = (matrix3 [1,0,0] [0,1,0] [0,0,1] [0,0,0])
strMeshData = StringStream ""
iVertCount = m.numVerts
iFaceCount = m.numFaces
aVerts = #()
aFaces = #()
for i=1 to iVertCount do
append aVerts (getVert m i)
for i=1 to iFaceCount do
append aFaces (getFace m i)
format "%\n" strName to:strMeshData
format "%\n" iVertCount to:strMeshData
format "%\n" iFaceCount to:strMeshData
format "%\n" (t.position) to:strMeshData
r = (t.rotation as eulerangles)
format "[%,%,%]\n" (degtorad r.x) (degtorad r.y) (degtorad r.z) to:strMeshData
for i=1 to iVertCount do format "%\n" (aVerts[i]) to:strMeshData
for i=1 to iFaceCount do format "%\n" (aFaces[i]) to:strMeshData
(strMeshData as string)
fn export file =
strData = StringStream ""
iMeshCount = 0
--try
for o in selection do
m = snapshot o
iMeshCount += 1
format "%" (exportMesh m (o.name)) to:strData
format "%\n" iMeshCount to:file
format "%" (strData as string) to:file
--catch
-- messageBox "Can not export meshes. Some object may not be geometry."
-- return undefined
holdMaxFile()
s = meshExportStruct()
strFile = getSaveFileName "Save mesh file" types:"*.msa|*.msa"
if (strFile != undefined) then
format "Exporting mesh...\n"
file = createFile strFile
if (s.export file) != undefined then
messageBox "Mesh exported."
else
messageBox "Mesh export failed. Check your MaxScript listener for details."
close file
format "Mesh exported.\n"
else
format "Mesh export cancelled.\n"
fetchMaxFile quiet:true
Animation export
Text animation format export.
Version 1.1
Version list:
1.0
- Basic KF animation export.
- Rotation choices
- euler angles
- angle axis
- quaternions
- Simple UI.
1.1
- Can save transformations as matrices.
rollout DialogRollout "Rollout"
group ""
label l1 "Ascii animation export"
label l2 "1.1"
label l3 ""
label l4 "Bake animations to every frame and export animation as"
label l5 "custom file format (*.aca)."
group "Rotations"
radiobuttons rotformat_rbn labels:#("Euler", "Angle axis", "Quaternion")
checkbox matrix_chk "Export transforms as matrices." checked:true
label l61
button export_btn " Export animation "
label l7 "Progress" align:#left
progressBar prgbar
on export_btn pressed do
objs = #()
transforms = #()
strFile = getSaveFileName "Save TXT" types:"*.txt|*.txt"
if ( strFile != "" ) do
format "Writing animation to file % ... please wait...\n" strFile
append objs o
fProgress = 0.0
fProgressStep = 100.0 / ((abs(animationRange.start - animationRange.end)) as float)
for f=animationRange.start to animationRange.end do
at time f
in coordsys #world
for o in objs do
try
strLine = (o.name)
strLine += " " + (f.frame as string)
if ( matrix_chk.checked ) then
t = o.transform
strLine += " " + (t.row1.x as string) + "," + (t.row1.y as string) + "," + (t.row1.z as string)
strLine += " " + (t.row2.x as string) + "," + (t.row2.y as string) + "," + (t.row2.z as string)
strLine += " " + (t.row3.x as string) + "," + (t.row3.y as string) + "," + (t.row3.z as string)
strLine += " " + (t.row4.x as string) + "," + (t.row4.y as string) + "," + (t.row4.z as string)
else
p = o.position
strLine += " " + (p.x as string) + "," + (p.y as string) + "," + (p.z as string)
r = o.rotation
case (rotformat_rbn.state) of
1: -- Euler
r = r as EulerAngles
strLine += " " + ((degToRad r.x) as string) + "," + ((degToRad r.y) as string) + "," + ((degToRad r.z) as string)
2: -- Angle axis
r = r as AngleAxis
strLine += " " + (r.axis.x as string) + "," + (r.axis.y as string) + "," + (r.axis.z as string) + "," + ((degtorad r.angle) as string)
3: -- Quaternion
strLine += " " + (r.x as string) + "," + (r.y as string) + "," + (r.z as string) + "," + (r.w as string)
format "%\n" strLine to:file
catch
format "Error when writing a file.\n"
close file
fProgress += fProgressStep
prgbar.value = (fProgress as integer)
format "Done\n"
close file
destroyDialog DialogRollout
if ( selection.count > 0 ) do
createDialog DialogRollout 300 280 modal:true
Import animation
file = openFile ( "c:/temp/testAnimation.txt" )
in coordsys #world
while (not eof file) do
with animate on
strLine = readLine file
a = filterString strLine " "
strName = a[1]
strFrame = a[2]
strPos = a[3]
strRot = a[4]
at time ( strFrame as integer )
sp = filterString strPos ","
sr = filterString strRot ","
p = Point3 (sp[1] as float) (sp[2] as float) (sp[3] as float)
r = Quat ((sr[1] as float)) ((sr[2] as float)) ((sr[3] as float)) ((sr[4] as float))
n = getNodeByName strName exact:true
n.rotation = r
n.position = p
close file
Blender toolit
Mesh import
import Blender
import bpy
def importMesh(filename):
file = open (filename)
strMeshCount = file.readline();
iMeshCount = int ( strMeshCount );
print "Mesh count: " + str (iMeshCount) + "\n";
print "Reading mesh\n";
for i in range (0, iMeshCount):
strMeshName = file.readline();
strMeshName = strMeshName.strip();
print "\tMesh name: " + strMeshName;
strVertCount = file.readline();
iVertCount = int ( strVertCount );
print "\tVertex count: " + str ( iVertCount );
strFaceCount = file.readline();
iFaceCount = int ( strFaceCount );
print "\tFace count: " + str ( iFaceCount );
strPosition = file.readline();
positionArray = [];
a = strPosition.split("[");
a = a[1].split("]");
strXYZ = a[0].split(",");
strX = strXYZ[0];
strY = strXYZ[1];
strZ = strXYZ[2];
positionArray.append(float(strX));
positionArray.append(float(strY));
positionArray.append(float(strZ));
strRotation = file.readline();
rotationArray = [];
a = strRotation.split("[");
strX = strXYZ[0];
strY = strXYZ[1];
strZ = strXYZ[2];
rotationArray.append(float(strX));
rotationArray.append(float(strY));
rotationArray.append(float(strZ));
print "\tReading vertices data\n";
verticesArray = [];
for j in range (0, iVertCount):
strVert = file.readline();
a = strVert.split("[");
strX = strXYZ[0];
strY = strXYZ[1];
strZ = strXYZ[2];
vertArray = [];
vertArray.append(float(strX));
vertArray.append(float(strY));
vertArray.append(float(strZ));
verticesArray.append( vertArray );
#print (vertArray);
print "\tReading face data\n"
facesArray = [];
for j in range (0, iFaceCount):
strFace = file.readline();
a = strFace.split("[");
strABC = a[0].split(",");
strA = strABC[0];
strB = strABC[1];
strC = strABC[2];
faceArray = [];
faceArray.append(int(strA)-1);
faceArray.append(int(strB)-1);
faceArray.append(int(strC)-1);
facesArray.append( faceArray );
#print (faceArray);
print "\tCreating mesh\n"
me = bpy.data.meshes.new(strMeshName);
me.verts.extend( verticesArray );
me.faces.extend( facesArray );
scn = bpy.data.scenes.active;
obj = scn.objects.new(me, strMeshName);
obj.RotX = rotationArray[0];
obj.RotY = rotationArray[1];
obj.RotZ = rotationArray[2];
obj.LocX = positionArray[0];
obj.LocY = positionArray[1];
obj.LocZ = positionArray[2];
print "Mesh readed.\n";
Blender.Window.FileSelector(importMesh, "Import")
Blender.Redraw()
Animation import
import Blender
from Blender import Mathutils
def importAnimation(filename):
iFrame = 0
fProgress = 0.0
iNumLines = sum(1 for line in open(filename))
fProgressStep = 100.0 / iNumLines
for strLine in file:
a = strLine.split(" ")
strName = a[0]
strFrame = a[1]
strRow1 = a[2]
strRow2 = a[3]
strRow3 = a[4]
strRow4 = a[5]
obj = Blender.Object.Get(strName)
Blender.Set("curframe",int(float(strFrame)))
iFrame += 1
row1X = float( strRow1.split(",")[0] )
row1Y = float( strRow1.split(",")[1] )
row1Z = float( strRow1.split(",")[2] )
row1 = [row1X, row1Y, row1Z, 0]
row2X = float( strRow2.split(",")[0] )
row2Y = float( strRow2.split(",")[1] )
row2Z = float( strRow2.split(",")[2] )
row2 = [row2X, row2Y, row2Z, 0]
row3X = float( strRow3.split(",")[0] )
row3Y = float( strRow3.split(",")[1] )
row3Z = float( strRow3.split(",")[2] )
row3 = [row3X, row3Y, row3Z, 0]
row4X = float( strRow4.split(",")[0] )
row4Y = float( strRow4.split(",")[1] )
row4Z = float( strRow4.split(",")[2] )
row4 = [row4X, row4Y, row4Z, 1]
m = Mathutils.Matrix(row1, row2, row3, row4)
obj.setMatrix(m)
obj.insertIpoKey(Blender.Object.LOCROT)
Blender.Window.DrawProgressBar(fProgress,"Importing animation")
Blender.Window.FileSelector(importAnimation, "Import")
print "Done"
Blender.Redraw()
