Juu en Maxia saatika sitten Maxwell käytä.. Mutta tämmöstä löyty Maxwell foorumilta..
http://www.maxwellrender.com/forum/viewtopic.php?t=1432&highlight="hi guys...
First of all Maxwell will render stills and then you need to compile them with another software like premier or etc...
So to create animation in Max you simply need to go: Renderer >> System and specify the location of the first .mxs file to be saved. Do the same for the output image.
For example I like to save my first frame mxs as 1.mxs and my output first frame image as 1.tga
Once you do that you have to specify the frames that Max+Maxwell you want to render! From the Common >> Common Parameters >> Time Output select the range of frames that you want to render. (like you normally do). Advice is as always not to render all frames in one shot but 20-20 or 50-50. Avoiding crashing....sometimes.
You can also uncheck the Render Frame Window option because Maxwell does not using Max's render window.
Once you hit render you will notice that maxwell will start exporting .mxs files first and then it will start render them.
Important is to mention that you need to specify infinite or 9999 for rendering time and a logic Sample Level e.g. 15
Also make sure that the Low Qaulity option is NOT checked. This will produce noise artifacts and strange animation output.
You can all these do easily from the cmd (command line) but I might explain that later if somene is intrested.
hope that helps,
Andronikos"
